hello
the objects setting window is not show
operating system : windows 10
software: sweet lights.
[image]
the window "Object settings" is not visible [fixed]
will_notley
Re: 3d viewer
It might be outside of your screen resolution (may be you changed monitors ?).
Please try this:
- close the window 3DView
- open the file "../YourLightshow/3DView/3dview.ini" with a notepad application
- delete the line starting with "Frm_ObjectsSettings ="
- save the file and close it
This will reset the location of the window "Object settings". Then you should be able to see it again.
Please try this:
will_notley
Re: the window "Object settings" is not visible
hello
thanks
thanks
- 3dview.ini
- (568 Bytes) Downloaded 1054 times
