Interface not recognised
usb to dmx (2009 - 2019)
djbuzby
Post by djbuzby »
I cannot get my D512 interface to work on one laptop. I have deleted and then reloaded twice but still not working (no flashing green light). The interface works fine on two other laptops.
Appreciate you help.
Running windows 64 bit
Thank you Karl
Re: Interface not recognised
What is the error message ?
djbuzby
Post by djbuzby »
Hi no error message only 'default 0 interfaces found'
have copied TheLightingController file from a know working laptop and the Sweetlight file from Program files (64) from a known laptop and still not working. replaced the original files
Thanks for helping?
We suggest you first to be sure you have a clean install:
- remove all copy/pasted files from any other computer
- unsintall the existing software
- delete all remaining files (in folder "Program_files")
- "double-click" on the master software (.EXE file available here: https://forum.thelightingcontroller.com ... f=85&t=114)
If the interface is still not found, then please follow this: https://forum.thelightingcontroller.com ... f=7&t=5158
Return to “D512”
