Request - Separate fader timer per scene
create scenes with steps
GermanTacos
Post by GermanTacos »
Currently in ShowXPress, it's only possible to toggle a global 'fade out' time from the Live preferences menu, however it is possible to make a fade in that is specific to the scene in the steps editor by using the 'duration' number. Would it be possible to get a fade out timer that can be customized for each different scene?
Re: Feature Request - Separate fader timer per scene
In "Live > Buttons", the fade in/out time is forced only when the button has the "fade in/out" option .
When the button does not have this option, the channels with the "fade/snap" option (below the vertical fader) set to "fade" will fade with the duration time fixed in the first step.
FYI, in "Live > Sequential List". the fade in/out times can be individually overrided.
GermanTacos
support wrote:When the button does not have this option, the channels with the "fade/snap" option (below the vertical fader) set to "fade" will fade with the duration time fixed in the first step.
I might just be dense, but I'm not seeing the fade/snap option, and I don't see a vertical fader slider option either.
Re: Request - Separate fader timer per scene
These options are in the tab "Editor > Steps".
SeekLighting
Post by SeekLighting »
Are you running version 8? Also the vertical slider fader option should be visible once you turn a steps scene into a fader scene by right clicking it and selecting the option.
Return to “Editor - Steps”
