stage setting window is not appearing [fixed]
djbarrios
Post by djbarrios »
when I right click, on stage setting or object setting or fixture setting next window is not appearing, any advices?
Re: stage setting window is not appearing
Maybe the windows are opening offscreen ? (did you change your screen configuration ?) You can try to delete the lines "Frm_xxx = ..." of the section "[Windows]" in the file "3DView/3dview.ini" (or delete the whole file) in your LightShow.
djbarrios
Post by djbarrios »
THANKS FOR THE HELP, everthing is working now 8-)
