Cable Interface does not work! [fixed]
already asked and answered questions
tombailey
Post by tombailey »
After installing the software first, i plugged in the cable Interface.
Now the software does not start, I just a get a mesage: There is one not compatible interface. Please remove it. After removing the Interface, Sweetlight starts correctly.
How can I go on.
Re: Cable Interface does not work!
tombailey
Post by tombailey »
Good Morning,
I bought the Sweetlight Interface cable, and of course I installed Sweetlight! The problem maybe is a littler bit more complex.
Is it possible to check the cable, maybe it is broken?
Thnak you?
We suggest you to install all software and check the interface with all.
(there is not problem to install all software in the same computer)
tombailey
Post by tombailey »
Works with Quick DMX!
Thank you very much.
Return to “Repetitive questions”
