"Fonction : TCP/IP : Listen error !"
Callum Allan
Post by Callum Allan »
Hello, I am currently having problems running showxpress with the external app. When starting showxpress I receive the message "Fonction : TCP/IP : Listen error !" I am currently running version 8.2.18 on OSX El Capitan 10.11.6 and have done several installs now. I have disabled the mac's firewall and tried opening every file in the application folder manually to ensure its trusted, I have also tried changing the port several times. I am out of ideas and can't find any other posts about this issue. Any ideas? Many Thanks :)
ShowXpress V8.2.28
DMX512 Interface
APC Midi Mini Controller
Re: "Fonction : TCP/IP : Listen error !"
BartKrap
Post by BartKrap »
Are you using any other program listening for artnet or using the port that artnet uses?
Callum Allan
BartKrap wrote:Are you using any other program listening for artnet or using the port that artnet uses?
No, I only have showxpress installed onto this machine.
ShowXpress V8.2.28
DMX512 Interface
