Can't find that one..
thank you
DMX-protocol
5 DMX channel mode
Control-channel 1- Horizontal movement (PAN) (within 540°)
Push slider up in order to move the head horizontally (PAN).
Gradual head adjustment from one end of the slider to the other (0-255, 128-center).
The head can be stopped at any position you wish.
Control-channel 2 - Vertical movement (TILT) (within 230°)
Push slider up in order to move the head vertically (TILT).
Control-channel 3 - Dimmer/strobe
Decimal Hexad. Percentage S/F Feature
0 7 00 07 0% 3% S Closed
8 134 08 86 3% 53% F Gradual adjustment of the dimmer intensity from 0 to 100 %
135 239 87 EF 53% 94% F Strobe-effect with increasing speed
240 255 F0 FF 94% 100% S Open
Control-channel 4 - Color macros
0 10 00 0A 0% 4% S Blackout
11 31 0B 1F 4% 12% S White (RGBW Macro white)
32 52 20 34 13% 20% S Red
53 73 35 49 21% 29% S Green
74 94 4A 5E 29% 37% S Blue
95 115 5F 73 37% 45% S White (pure white)
116 136 74 88 45% 53% S Yellow
137 157 89 9D 54% 62% S Cyan
158 178 9E B2 62% 70% S Magenta
179 199 B3 C7 70% 78% S Color Change Macro 1
200 220 C8 DC 78% 86% S Color Change Macro 2
221 241 DD F1 87% 95% S Color Change Macro 3
242 252 F2 FC 95% 99% S Color Change Macro 4
253 255 FD FF 99% 100% S Color Change Macro 5
29/34 00063749.DOC, Version 1.1
Control-channel 5 - gobos, gobo shake
0 7 00 07 0% 3% S Open
8 15 08 0F 3% 6% S Gobo 1
16 23 10 17 6% 9% S Gobo 2
24 31 18 1F 9% 12% S Gobo 3
32 39 20 27 13% 15% S Gobo 4
40 47 28 2F 16% 18% S Gobo 5
48 55 30 37 19% 22% S Gobo 6
56 63 38 3F 22% 25% S Gobo 7
64 71 40 47 25% 28% S Gobo 8
72 79 48 4F 28% 31% S Gobo 9
80 94 50 5E 31% 37% F Gobo 1 shake with increasing speed
95 109 5F 6D 37% 43% F Gobo 2 shake with increasing speed
110 124 6E 7C 43% 49% F Gobo 3 shake with increasing speed
125 139 7D 8B 49% 55% F Gobo 4 shake with increasing speed
140 154 8C 9A 55% 60% F Gobo 5 shake with increasing speed
155 169 9B A9 61% 66% F Gobo 6 shake with increasing speed
170 184 AA B8 67% 72% F Gobo 7 shake with increasing speed
185 199 B9 C7 73% 78% F Gobo 8 shake with increasing speed
200 214 C8 D6 78% 84% F Gobo 9 shake with increasing speed
215 235 D7 EB 84% 92% F Forwards rainbow effect with increasing speed
236 255 EC FF 93% 100% F Backwards rainbow effect with increasing speed
14 DMX channel mode
Control-channel 1 - Horizontal movement (PAN) (within 540°)
Control-channel 2 - PAN-movement with 16 Bit-resolution
Control-channel 3 - Vertical movement (TILT) (within 230°)
Control-channel 4 - TILT-movement with 16 Bit-resolution
Control-channel 5 - PAN/TILT-speed
0 255 00 FF 0% 100% F Decreasing speed (vector mode)
Control-channel 6 - Dimmer/strobe
135 232 87 E8 53% 91% F Strobe-effect with increasing speed
233 255 E9 FF 91% 100% S Open
30/34 00063749.DOC, Version 1.1
Control-channel 7 - Red
0 255 00 FF 0% 100% S Red (0=off, 255=100% red)
Control-channel 8 - Green
0 255 00 FF 0% 100% S Green (0=off, 255=100% green)
Control-channel 9 - Blue
0 255 00 FF 0% 100% S Blue (0=off, 255=100% blue)
Control-channel 10 - White
0 255 00 FF 0% 100% S White (0=off, 255=100% white)
Control-channel 11 - Color macros
0 10 00 0A 0% 4% S No function
Control-channel 12 - RGBW speed
31/34 00063749.DOC, Version 1.1
Control-channel 13 - Motion macros
0 7 00 07 0% 3% S No function
8 23 08 17 3% 9% S Motion macro 1
24 39 18 27 9% 15% S Motion macro 2
40 55 28 37 16% 22% S Motion macro 3
56 71 38 47 22% 28% S Motion macro 4
72 87 48 57 28% 34% S Motion macro 5
88 103 58 67 35% 40% S Motion macro 6
104 119 68 77 41% 47% S Motion macro 7
120 135 78 87 47% 53% S Motion macro 8
136 151 88 97 53% 59% S Sound-controlled Motion macro 1
152 167 98 A7 60% 65% S Sound-controlled Motion macro 2
168 183 A8 B7 66% 72% S Sound-controlled Motion macro 3
184 199 B8 C7 72% 78% S Sound-controlled Motion macro 4
200 215 C8 D7 78% 84% S Sound-controlled Motion macro 5
216 231 D8 E7 85% 91% S Sound-controlled Motion macro 6
232 247 E8 F7 91% 97% S Sound-controlled Motion macro 7
248 255 F8 FF 97% 100% S Sound-controlled Motion macro 8
Control-channel 14 - gobos, gobo shake
Eurolite - LED TMH-8
Re: Eurolite LED TMH-8 Moving-Head Fixture
This link does not work.
Please post the correct link.
Manual can ben found on the seller page.
https://www.thomann.de/gb/eurolite_led_ ... d_spot.htm
Thank You
Thank You
I tried to do this by myself. I joined tht .txt document.
Is that good?
Is that good?
- TMH8.txt
- 5 channel DMX
- (1.29 KiB) Downloaded 719 times
