Active and unactive channels between steps [done]
create scenes with steps
samwise309
Post by samwise309 »
I was wondering if it's possible to have a step scene where, in the first step, you have a channel active, and then in the next step of that scene have that same channel deactivated. I'm trying to make wipes that don't require 12 different step scenes, executed as a chase and paused at the end.
Re: Active and unactive channels between steps?
Sorry but this is not possible.
samwise309
This would be extremely useful if it's possible for the next major update :D
Bobnjul
Post by Bobnjul »
Totally agree!
MortaR
Post by MortaR »
Totally agree too.
thorehl
Post by thorehl »
1+
Thore
Controller: 2x Akai APC mini
my DIY light mixer
SkottyRock
Post by SkottyRock »
Would be extremely helpful!!
dmxshows
Post by dmxshows »
I did it manually deleting the unwanted lines of the scene xml file (I market as "XX" to show what lines to delete), it is not a big deal but certainly it would be pretty very usefull if the programmer adds an "unlink" or "unchain" button to the step editor when doing multistep scenes and you just want to do something just on a fixture in one step and something else with other fixture in other step. This is my example:
THIS IS THE ORIGINAL/MODIFIED XML FILE MADE WITH SHOWEXPRESS with the deleted lines:
<?xml version="1.0" encoding="UTF-8"?>
<Scene>
<Fixtures>
<Fixture id="1472590267" name="PAR64_#1" model="PAR64"/>
<Fixture id="1472590268" name="PAR64_#2" model="PAR64"/>
<Fixture id="1472590269" name="PAR64_#3" model="PAR64"/>
<Fixture id="1472590270" name="PAR64_#4" model="PAR64"/>
<Fixture id="1472590271" name="PAR64_#5" model="PAR64"/>
<Fixture id="1472590272" name="PAR64_#6" model="PAR64"/>
</Fixtures>
<Steps>
<Step length="50">
<Fixture id="1472590267">
<Channel index="3" name="dimmer" value="255"/>
<Channel index="4" name="red" value="0"/>
<Channel index="5" name="green" value="255"/>
<Channel index="6" name="blue" value="255"/>
</Fixture>
<Fixture id="1472590268">
</Fixture>
<Fixture id="1472590269">
</Fixture>
XX <Fixture id="1472590270">
XX <Channel index="3" name="dimmer" value="0"/>
XX <Channel index="4" name="red" value="0"/>
XX <Channel index="5" name="green" value="0"/>
XX <Channel index="6" name="blue" value="0"/>
XX </Fixture>
XX <Fixture id="1472590271">
XX </Fixture>
XX <Fixture id="1472590272">
XX </Fixture>
XX </Step>
<Step length="50">
XX <Fixture id="1472590267">
XX </Fixture>
XX <Fixture id="1472590268">
XX </Fixture>
XX <Fixture id="1472590269">
XX </Fixture>
</Fixture>
</Fixture>
</Fixture>
</Step>
</Steps>
</Scene>
What it does is:
in the first step: makes lamp 1, 2 and 3 purple keeping 4, 5 and 6 in the "whatever color" they are
in the second step: lamp 1, 2 and 3 returns to their original "whatever color", changing 4, 5 and 6 to purple
Please notice that you will have to re erase this line everytime that you edit the scene.
HOPE THIS HELPS PALS
Noted.
DeeStage
Post by DeeStage »
This feature would be so much useful !!!
+1
Please take this feature and more possibilities as main mart of Version 10
Return to “Editor - Steps”
