only one moving head will light up out of 2 and a parcan
Brett
Post by Brett »
I have created a few scenes using 3d and now all of a sudden only one moving head (chauvet 255) will turn on (out of 2) and I have 10 parcans and all of a sudden parcan number 10 turns on with the one moving head. The moving head that doesn't light up is controlling the other moving head!!!! any suggestions,
Thanks in Advance Brett
Brett
Re: only one moving head will light up out of 2 and a parcan
Post by Brett »
If I could send you my file to have a look that would be awesome thanks guys
Brett
Post by Brett »
Freedom Par Hex 4 (8CH).txt
Parcans
(595 Bytes) Downloaded 1027 times
Intimidator Spot 255 IRC (13CH).txt
Moving head fixture
(2.26 KiB) Downloaded 982 times
Most of the times, the reason is: viewtopic.php?f=72&t=3614
Brett
Post by Brett »
Sorry guys I am quite new to this is, do I then go through all my scenes or generatored moves to find where the problem is and is just a matter of disabling a channel that should not be on (in that scene or move), it would be good to do so I know for next time cheers Brett
Brett
Post by Brett »
I have copied my lightshow I then went through all scenes and generated moves deleted them one by one to see if this alleviated the problem but it didn't so not sure!!! Thanks brett
