Error message "There is no personality file for this ..."
There is no personality file for this fixture, so it is removed from the dmx addressing list
This means there is fixture declared in Editor => Steps, and its personality file (.txt) is not in the lightshow.
This might happen if you manually delete or rename a ".txt" file in the folder "home_directory/TheLightingController/Lightshows/YourLightshow/fixtures/".
If you edit the file "home_directory/TheLightingController/Lightshows/YourLightshow/fixtures.ini", you will find lines starting with "model = NameOfYourFixture ".
For instance, if you read "model = RGBparcan", the file "RGBparcan.txt" must be present in the folder "home_directory/TheLightingController/Lightshows/YourLightshow/fixtures/".
Return to “Editor - Fixtures”
