[Bug report] fast fader movement turns off scene (again)
BartKrap
Post by BartKrap »
Hey support,
Just found an old bug that seems to have reappeard.
When moving a fader from 0 to 100 as fast as possible it makes the scene turn off.
Tested on 2 apc mini's, multiple show files and different scenes within those shows.
Please let me know if you need any aditional testing or info.
Re: [Bug report] fast fader movement turns off scene (again)
Please tell with which previous version there was no problem, and with which version there is again the problem.
BartKrap
Post by BartKrap »
support wrote:Please tell with which previous version there was no problem, and with which version there is again the problem.
I'm not quite sure but I believe it was fixed in one of the fix files for V8.1.23.
I'm currently using 8.2.13
BartKrap
Post by BartKrap »
Any updates on this?
We are still not able to reproduce this.
Can you please post a video showing the problem ?
BartKrap
Post by BartKrap »
https://www.youtube.com/watch?v=_LdI20z3H3w
As you can see in the video, when I move the fader up slowly, the strobe blinks just like normal. When the fader is moved fast, it sometimes turns of the button and sometimes doesn't (about 50/50).
The "again" here is maybe a bit misleading since the last time the scene didn't turn off when moving the fader down fast. Which was fixed in 8.2.7.
The scene is a simple 0 on step 1 and 255 on step 2 with a fader button.
I hope this helps.
Greetz
Bart
