V6.0 in action with DJ Mikey Mike and Direct Sound (10:14)
gigs made with the software
directsound
Post by directsound »
Here is ShowXpress 6.0 in action. I had one lock up with the program but I was doing a lot of scene building and DMX addresss changing because I was having an issue with my laser Im not the software as far a s I know Take a look at this video and you can see me yse it live from time to time ....I give it 4 out 5 stars so far there are a few things I would like to see get incorperated but it work just fine I just need a second moniter to see it all ...This would be great in a club setting with 2 big displays you wow anyway here is the link enjoy
http://www.youtube.com/watch?v=w8skpI1UVZE
Please leave a comment and let give me some feedback on what you would change if anything
thanks
mm
Thanks,
From DJ Mikey Mike
http://www.directsound.com
Re: ShowXpress 6.0 in action with DJ Mikey Mike and Direct Sound
Thank you. This video shows clearly the concept of Editor and Live.
Just one remark: to do such chase effects with the rgb pars, you should try to do them with the application 'Generator'.
To open Generator, first select the group of pars and then click on the icon "Generator" in the tool bar menu.
directsound
I have only used the gen with my moving heads Ill give it a try soon
I just got a sweelight box is this the fourm to post videos on that or is this just a Chauvet fourm''MM
Thanks,
From DJ Mikey Mike
Yes SweetLight and ShowXpress are similar products.
SweetLight technical team and ShowXpress technical team are working very closely, trying to make the best possible software and interfaces.
Afterwards ShowXpress is closer to the American market and SweetLight is closer to the European market.
Partnership between SweetLight and ShowXpress is very strong and this forum is exclusively for technical things, so there is no problem to post ShowXpress and SweetLight videos in this forum.
directsound
Re: V6.0 in action with DJ Mikey Mike and Direct Sound [10:14]
Great neturel it is :-)
Thanks,
From DJ Mikey Mike
Return to “Gigs from users”
