when assigning a midi fader to a step selector in live mode (in my case 40 steps) and you move the fader fast and when you suddenly stop, the fader ends on the correct step but the button ends up unpressed. Normally, when you start using the fader, the buttons should be kept "pressed in" until you manually unclick the button.
Don't know if this only happens in windows version.
"preset button" stops working on fast movement
Light_user
Re: Bug: step fader stops working on fast movement
We are not able to reproduce (using latest fix file : 8.2.12)
Light_user
I have send an email to support with the show in attachement.
regards
Mattias
regards
Mattias
We are not able to reproduce the problem with your lightshow to.
Please post a video showing this problem.
