Small red dots in the view [fixed]
jwhite
Post by jwhite »
What are these dots? They seem to affect my non pixel fixtures, but I can't figure out how to delete them.
[image]
Re: Dots
Looks like visual glitches.
Please ignore them.
We are not able to reproduce them.
If you can do this easily, please send us your lightshow, and tell us your Operating System.
Re: Dots
Seems to be 0x0 matrix fixtures, you should be able to delete them by editing the "fixtures.ini" file in the Pixels directory of your lightshow.
Re: Dots
You can also post the file ("home_directory/TheLightingController/LightShows/YourLightshow/Pixels/fixtures.ini").
We will check it.
jwhite
Re: Dots
Post by jwhite »
See attached.
fixtures.ini
(2.41 KiB) Downloaded 1155 times
Re: Dots
Fixtures_4 to Fixtures_8 have PixelWidth = 0 and PixelHeight = 0, that's the problem.
You can change PixelWidth and PixelHeight to 1 for example or you can delete Fixtures_4 to Fixtures_8 sections (lines 74 to 158) as in the attached file.
If you are able to reproduce this, please let us know how to.
fixtures.ini
(1.35 KiB) Downloaded 1178 times
jwhite
Re: Small red dots in the view [fixed]
Post by jwhite »
Thanks for the updated file. That did correct the issue!
Return to “Pixels”
