[request] Better visualisation when button pressed [done]
Light_user
Post by Light_user »
Request: better visualisation when a button in the live view is pressed. for example a clear 3D 'push down' effect or a Big black stroke around the button when pressed. At this moment, when using colors on the buttons, it's not clear when a button is pressed.
Re: Feature request: Better visualisation when button presse
button off: black text and bright color
button on: white text and darker color
Light_user
When you have 5 buttons in the same color, then you can see which button is pressed.
When you have 40 buttons in 14 colors (like i do), the 'darker color when pressed' doesn't make a visual difference to the other buttons.
When you are doing DMX light control in a live environment, you need to see immediately which button is pressed.
And this is not the case with the current version.
Can you please send us a screenshot of your "Live" window ?
viewtopic.php?f=3&t=19
Light_user
I have send it in an email.
We can not reduce the size of the button, because of the possible icons in it.
Anyway, we keep in mind the problem.
Lighter007
Post by Lighter007 »
What about a red-colorer border (instead of black) for pressed buttons?
Greetings from Germany! :)
This is possible.
We will come back to you asap regarding this.
Re: [request] Better visualisation when button pressed [done
Done in "fix for version 8.2.13".
