Fade out not working right?
jcasi
Post by jcasi »
When I choose fade out on a scene it makes it where that scene is no longer on at all.
Example. I have front pars on for 2 minutes. after 2 minutes I have the" "off command" to turn them off and go blank. I don't want an abrupt off, so I right click, properties on the scene, click fade out, and now in the timeline when it gets to that scene, the lights do not come on at all (they do when I have fade out unchecked)
Not real sure what would cause this? I have upgraded to the most recent SW.
Re: Fade out not working right?
Please confirm the channels are dimmable channels.
viewtopic.php?f=72&t=4044
JohnRichards
Post by JohnRichards »
The fade-out settings in buttons will not work in timelines. You will have to make a scene that fades out for timeline.
John
jcasi
Post by jcasi »
Its definitely dimmable. Its a RGBW LED light with a dimmer channel.
I will try creating a scene to dim out. That's kind of a pain when there is a check box to "fade out".
JohnRichards
The fade-out is only for buttons, but I suggest you try the sequential list and see if that suits your requirements
John
jcasi wrote:Its definitely dimmable. Its a RGBW LED light with a dimmer channel.
The "fade out" checkbox was recently added in TimeLine, we will check if something goes wrong ...
JohnRichards
Thanks Niffo,
Is this fade out as per live settings, or can each scene have a fade out value?
John
There is only one fade in/out time for both Live Buttons and Live TimeLine.
In Sequential List, there is one fade in plus one fade out time, for each line.
After checking, fade out works here.
But the scene must not be followed by another scene in the same timeline, otherwise the next scene cuts the previous one.
Return to “Live - TimeLine”
