Qtx - Rp4 4-Channel DMX Relay Pack
choosy
Post by choosy »
i have a qtx rp4 relay pack can u do a profile for it to use with 4 par 16 lights thanks
Operation
DIP Switch settings
DIP switch ON Setting
10 DMX control - Set start address using DIP switches 1- 9
1 Channel 1 ON
2 Channel 2 ON DIP switch 10 is OFF
3 Channel 3 ON
4 Channel 4 ON
The RP4 can be used as a 4 Channel DMX switch pack or for standalone operation:
Stand alone: Set DIP switch 10 to OFF then use switch 1 to 4 to turn on / turn off each channel DMX Mode: Set DIP switch 10 to ON and use DIP switches 1 - 9 to set the DMX start address.
In DMX mode, 4 channels (starting at the selected start address) can be used to turn on or turn off each channel by adjusting the slider accordingly (000/0% = OFF, 255/100% = ON)
http://avslgroup.com/assets/manuals/1/5/154111UK.pdf
Re: QTX RP4 4-Channel DMX Relay Pack
Done.
choosy
Re: Qtx - Rp4 4-Channel DMX Relay Pack
Post by choosy »
thanks for the help
