I'm learning the software and have a problem where not matter what Gobo I set, all that displays in 3D view is an open spot. Colours and movement are fine, just not seeing the selected Gobos.
Software version: ShowXpress 8.1.29
Fixtures: Chauvet Intimidator LED Spot 150
While editing steps, no matter which gobo I set, the icon on the onscreen controller shows '?'
Any assistance/advice would be appreciated.
No Gobos in 3D View
Re: No Gobos in 3D View
Please see the attached file with revised profiles. These will work in your 3D view and allow you to see the gobos properly. We will update the master EXE file so it will be corrected on the next software release.
- Spot150.zip
- (1.77 KiB) Downloaded 932 times
Allan Reiss
Senior Product Manager
CHAUVET DJ
CHAUVET DJ
Thank you Allan. Greatly appreciated. Those profiles certainly worked.
Cheers,
Lee.
Cheers,
Lee.
