Editor works in 3DView, but not Live [fixed]
dixxy
Post by dixxy »
I am having trouble getting the live window to work with the #D view. In the editor ican see my sceen in 3D view no problem, but the live window nothing moves in 3D view. I hav clicked the 3D button, but still nothing?
Am i doing something wrong?
Thanks,
dixxy
dixxy
Re: Live does not work in 3D view
Post by dixxy »
hello again....found the answer myself....
you need to have the editor window closed in order to see acion in 3D view with live window...
thanks to DJ Mikey Mike and his VERY usefull videos on YouTube...That is were i found the answer.
Hope this can help somebody else.
dixxy
At least you need to have the "3D" button off in Editor. It's because Editor has the highest priority on the stream (even in DMX).
dixxy
Post by dixxy »
Thanks for the reply,
yes now that you mentionned it, i see that....
pogjack
Re: Editor works in 3DView, but not Live [fixed]
Post by pogjack »
I also noticed that too. If you want to edit some scenes without messing with the lights that are on 3D view or dmx mode you can. Those lights will not be affected while you change other lights, but once you select a channel that is being used in 3D or DMX it will override those.
Return to “General”
