DMX CH #s
create scenes with steps
VisionaryLD
DMX CH #s
Post by VisionaryLD »
In previous versions, the dmx value under each handle represented the actual dmx value as it existed in each universe 1-512.
Now, the dmx value under each handle only represents the dmx value by fixture 1-max ch# per fixture.
This change complicates patching of outboard control surfaces significantly (dmx or midi) because I can no longer see the actual dmx address per channel.
These #s serve no purpose in this current configuration.
Can you please change this back or, offer a toggle between the 2.
Thank you.
[image]
Re: DMX CH #s
FYI: viewtopic.php?f=69&t=4706
The new patch in V8 si also fixtures based (see page 11 in the manual).
https://www.youtube.com/watch?v=vX3cHwX_Qsk
VisionaryLD
Re: DMX CH #s
Thank you Support.
This is an acceptable workaround.
Return to “Editor - Steps”
