Change Auto BPM speed values on the fly
osuarez
Post by osuarez »
Currently within a page I have a number of steps that are driven by Random play, and I have to click on each button in order to change the Beats. The ask is to add Speed Properties to the page level so that you can change all buttons under the page to the same Beats, 1,2,3,4,8. This will allow quick changes on the fly.
Re: Auto BPM Speed Values
To change speed of several scenes on the fly, we suggest you to use the "Master Speed" fader.
osuarez
Post by osuarez »
Hello Support, Yes I do understand the use of the speed fader for manual speed items. But this request is for when one is using Auto BPM settings. Are you saying that the speed fader will also affect the Auto BPM settings as well?
No, Master Speed overrides exclusively "Manual speed".
To have different BPM settings (1, 2, 4, 8) for same scene, you have create one button for each setting and use them in a "solo button" page.
osuarez
Re: Change Auto BPM speed values on the fly
Post by osuarez »
okay so maybe I am not explaining myself sufficiently. I have a tab and within it a page of steps (17) which in turn are each set up to Auto BPM. The page is configured with Random, and I was looking to have the ability to select the page and from there be able to change the Auto BPM to 1,2,3,4, or 8 instead of having to do it on each of the 16 steps within the page. 1 of the buttons on the page is a Macro which when random selects it activates two buttons within the page.
I believe it would be easier for the users if when using the Auto BPM function if instead of having to select each button to make a universal change it could be done the same way as on the button but at the page level so that all buttons within the page would receive the same BPM setting.
We understand you, but this is unfortunately not possible in our software.
osuarez
Post by osuarez »
okay thanks that is what I was looking for.
