DMX input not working DMXKing ultraDMXmicro
computer, driver, ...
EvanHopps
Post by EvanHopps »
I am trying to use a small 12 channel DMX console as a DMX input to be able to use the faders to control some Source 4s through the software, rather than using a separate DMX line to the stage just for those lights.
I have a Xpress512Plus for the DMX output and a DMX King ultraDMX Micro (http://dmxking.com/usbdmx/ultradmxmicro) that hopefully will be used as the input. I have the DMX King set as an input device using their config software and I can see it receiving inputs on the correct channels on their software, I just cant seem to get showXpress to use it, or really see it at all.
I understand that this device may not be compatible with showXpress, and if that is the case, what device should I look into to enable DMX input?
Re: DMX input not working DMXKing ultraDMXmicro
To have dmx in and dmx out with our software, you have to use the interface "Rack".
viewtopic.php?f=3&t=5
Return to “General hardware”
