V8 - How to enable fade in/out option ? [fixed]
shazammagic
Post by shazammagic »
I was very excited to see this feature added to the list of updates for v. 8.1.10!
Unfortunately, I'm not seeing how to implement/activate this feature in Live > Timeline. Could you provide some more info? Thanks much!
Re: How to enable fade in/out option for scenes in timeline?
In the popup menu "Properties" of the block.
shazammagic
Re: V8 - How to enable fade in/out option ? [fixed]
Thanks for the clarification. Looks like it only allows for fade out of the light scene, not the accompanying audio track?
Yes, only the light scene.
JT drumhead
Post by JT drumhead »
HI. I am new to ShowXpress running version 8.1.29. I was recently instructed, in order to do crossfades from scene to scene within the timeline, I must use the "buttons" mode and program them in as a Fade in and fade out time per button. THEN, the fade times would translate over to my timeline per scene as long as that button/scene was in the timeline. That does NOT work however. May other programs allow you to do a "Crossfade" from scene to scene and manipilate the crossfade times in the timeline directly. Does this SW have this function somewhere? I am very confused on how to do crossfades in timeline. Please explain in detail as the Properties in the Block area description I did not understand in previous post. Thanks
JT
Return to “Live - TimeLine”
