Custom Profile not working in 3d [fixed]
So I have recently started to build up my different setups in 3d view (which is sweet!). I have gotten stuck with a fixtures beam not showing up and tried changing the profile several times. Here is the profile, is there any reason it shouldn't show up with a white beam with the shutter and dimmer up?
- 5r 20 CH Touchscreen V2.txt
- Profile
- (752 Bytes) Downloaded 849 times
Re: Custom Profile not working in 3d
There must be some color levels, in channel "color".
If not, you have to rename this channel by "color_macro" for instance.
