Export / Import [fixed]
jkeefauver
Post by jkeefauver »
Am using 6.25 version. Worked up scenes on home PC and tried to export the light show and then import onto laptop running same software. Everything seems to come over except that my 3D model now has only 2 lights in it. The scenes are all there and they appear to run in the editor but the 3D window shows nothing. I am using the "default" name for my light show - should I rename that prior to trying this? Any advice would be greatly appreciated. Thank you.
Re: Export / Import
Renaming the lightshow would be better, since the lightshow "Default" is existing in each installed software. This would avoid files conflicts.
For your info, next software version will not allow to import a lightshow, when another lightshow with same name is already existing.
jkeefauver
Re: Export / Import
Great, thanks for the info. I assume you have to "rename" it thru Windows as I haven't found a command in the software to do that, correct?
Re: Export / Import
Yes. You can open the lightshow folder via "ControlBoard->Settings->open light shows folder" button. And then use Windows commands for rename, delete, copy, ... functions.
