Dialog prompts shown on wrong screen
Alan_G13
Post by Alan_G13 »
Hi
If the Screen Control window is left open (for example at the end of playing a video file) with the output sent to a secondary monitor, any system prompts (eg Are you sure you want to quit, Are you sure you want to remove the button etc etc etc) are shown on the secondary monitor and not the primary monitor. If the user has visual sight of the secondary monitor it's not too bad as they can move the mouse pointer and click the appropriate button thereby dismissing the prompt. However, if the secondary monitor is a projector screen that isn't visible to the user, there is no way for them to be able to navigate the mouse to the correct location to click a button, and with the prompts being dialog until they're dismissed there's no way of clicking anything else within ShowExpress.
This leads them to believe that the software has crashed (which it hasn't, it's waiting for user input) and the only way they can get out of it is to use Ctr+Alt+Delete to quit the programme altogether
Can the dialog prompts be correctly shown on the primary monitor as they should be, even if the Screen Control window is still open
Re: Dialog prompts shown on wrong screen
Could you please post (or email) a screenshot showing this problem ?
Alan_G13
Post by Alan_G13 »
It's happening on all of the installs where we have three video outputs set up in Windows. The three outputs are
1 - Standard primary monitor connected via VGA
2 - Touchscreen monitor connected via DVI which has the Buttons window in SX displayed
3 - Output to projectors connected via HDMI
The Desktop is extended to all three displays and the prompts are being displayed on the third (HDMI) output - ie the projector
I'll get one of the techs to take a picture of the primary PC monitor, touchscreen monitor and the projector screen which is where the prompts are being displayed if it helps you. Wouldn't have thought it would though as it will just show in pictures what I'm describing here ?
Alan_G13
Post by Alan_G13 »
Hi
Sorry for delay, been waiting for the guys to send me the images
I've emailed three imgages to you -
1 shows two monitors, the primary screen with SX with drop down 'Remove Buton' being selected and the touchscreen with the live child window
2 shows the projector screen with the Screen Control window on and the confirmation prompt to remove the button
3 shows the prompt a bit clearer
As you can see from the images, the projector screen isn't visible to the user, so they think SX has crashed when in fact it hasn't, it's waiting for them to click either Yes or No on the dialog prompt, which they can't do as they can't see it. They either have ti use Task Manager to quit the programme or get someone who can view the projector screen to direct them as to where the mouse pointer is so they can click the appropriate button
If you can get the prompts to show on the primary monitor that would solve the issue
Alan_G13
Post by Alan_G13 »
Images added here as well so others can hopefully benefit
Image Primary monitor with SX and secondary touchscreen monitor with Live Child
Image Projector screen (prompt is a 'white out'!)
Image Prompt shown on projector screen
Lighter007
Post by Lighter007 »
Hi
I got your point. But isn't this rather an OS problem than a software error? Are you sure you selected your PC monitor as prinary screen?
Greetings from Germany! :)
Alan_G13
Post by Alan_G13 »
Hi
The primary monitor is selected correctly within the OS and is definitely not the one that displays the dialog prompts, which are shown on the projector screen (monitor 3 and not set to primary in the pictures shown) if the Screen Control window is open within SX
Alan_G13
Post by Alan_G13 »
Hi
Have you managed to recreate this problem yet, or better still found a solution to it ?
It's becoming more and more of an issue with the guys out in the venues and they're ringing me most days now for an update. SX is the only software that this issue happens in if that gives you any more of a clue. Any other software the guys run in exactly the same computer environment displays prompts on the primary screen as you'd expect.
I'm not a big fan of using Ctrl+Alt+Del to kill a process, but it's the only option open to them if there's a dialog prompt shown and there's nobody to help them point the mouse at the right button to click on the projector screen - plus it looks incredibly bad to the audience to suddenly see prompts being shown on projector screens
We checked with 3 screens, and the requester message is always displayed in the correct window.
Alan_G13
Post by Alan_G13 »
Hi
Well, it's definitely happening for us, as you can see by the images. Do you have any suggestions that we could try to see if we can find a solution ?
Return to “Live - TimeLine”
