Multi universe - universe selection with one USB box [fixed]
rockinmo816
Post by rockinmo816 »
Have a problem and don't know the best way to "fix it".
We currently are running the latest version of 7.x with two DMX 512 box universes. We almost have both universes full, and are adding more fixtures in the next few weeks, so most likely will require a third universe.
Now, here is the problem. There are numerous occasions where we run multiple events simultaneously, where our gear is split up in different locations/events. We send one dmx box to each location with it's own operator. The lighting that goes to each event differs every time. Movers here, pars there, strobes here, etc. This is NEVER the same. To setup all of our fixtures into the two universes, we can successfully program our shows utilizing both DMX 512 boxes. Now, when we split gear up, and we want to use fixtures that have been assigned to universe 2, and we only have one box, I can't even access universe 2.
So... How can we utilize one master light show with all of our fixtures preprogrammed and scenes configured, and then setup our live board according to what fixtures we are utilizing for that event. I am OK with doing some quick and easy setup/programming. But having to readdress and configured most of the show for every event is very time consuming.
Having a DMX to USB interface that supported more then 1 universe without having to use multiple boxes would solve the issue. Also if we just got 2 more USB boxes that would also solve the problem, but would also have a significant cost. Making light shows for every possible fixture option "IS" an option, but I don't even want to consider the time it would take to do that. What other options are there? Am I missing something? Thanks!
Re: Multi universe - universe selection with one USB box
Sorry, but it is presently not possible to run the lightshow of the second universe, when only one interface is plugged to the computer.
However, we note your problem. We will take some time to think about it.
rockinmo816
Is there a USB adapter that will support more then one universe?? We've gotta find a solution quick.
Josh
We propose only "one universe" interfaces (viewtopic.php?f=3&t=5).
Please note that coming V8 will open a second Artnet universe for each dmx interface ; but V8 is not available as "stable" for now.
rockinmo816
I just spent some time researching ArtNet last night, so I am getting familiar with it finally. So right now (V7), One USB universe = one artnet universe. You're saying for V8 (future) One USB universe = two artnet universes? Also, will you support hardware to convert Artnet into DMX, or will that still be open source?
I am either going to have to buy 4 more dmx512's (three universes for each setup we have) and a whole crap ton more of DMX, or switch to ArtNet fully and cross my fingers V8 comes out sooner than later.
Josh
With V7
viewtopic.php?f=81&t=3741
With V8
One dmx interface (except interface Cable) opens 2 Artnet universes:
- the first one is the mirror of the dmx interface
- the second one offers 512 more channels
Which makes a total of 1024 Artnet channels, with one dmx interface.
rockinmo816
Perfect!!
Any timeline on when you expect V8 to launch into production mode? (out of Alpha and Beta testing)
lse
Post by lse »
I've been asking for a multi universe artnet key for a while. I run multiple shows with multiple universes.
V8 beta should be soon.
We are not able to give any date for first V8 production.
Re: Multi universe - universe selection with one USB box [fi
Fixed in V8.1.15.
viewtopic.php?f=2&t=4528
