selecting interfaces for each universe
kjensen77
Post by kjensen77 »
How can you select which interface is associated with which universe?
I am using an x-factor & a SAA. i need the ssa to be universe 1 but when i plug in the x-factor that one gets assigned to universe 1 & ssa to universe 2.
Reason is my external dmx board does not work via dmx in on x-factor but does work via dmx in on ssa unit.
Re: selecting interfaces for each universe
The order of the universes is given by the operating system.
If you reverse the usb connexions, the order should be reversed.
FYI, V8.1.15 has a software patch for universes.
viewtopic.php?f=2&t=4528
Return to “ControlBoard”
