The fix files have some more improvements
36 improvements
All - Mac - any mouse click, anywhere in the application, gives the focus to the application
Editor - clicking on a pan/tilt point, in Pan/Tilt area, automatically changes the current step
Editor - bigger "step" display in 2DView area, in play mode
Editor - message "Press stop to exit from play mode" in 2DView area, in play mode
Editor - in Pan/Tilt tab, pan/tilt infos are grayed when "lock" is checked
Editor - in the RGB tab , the "color" cursor can not go over the colorwheel area
Generator - no crash with curves having 2 points on same time
Live - can trigger another timeline project with a button, when playing a project in TimeLine
Live - non alpha keys do not switch off the buttons
Live - space bar does not interact over focused button
Live - <ctrl + shift + key> for "old Macro" mode (one button only)
Live - tooltips for pause, freeze and beat
Timeline - easier event selection with the lasso
TimeLine - tooltips for buttons play, stop, ...
TimeLine - can drop an event at the very end of the timeline
jaxx00974
Re: The fix files have some more improvements
Post by jaxx00974 »
pity as I used this to quickly choose white from the three RGB sliders :-) Nnot a problem though.
Can you please explain more fully ? I could already use a Live button to start a Timeline whilst a timline was playing ?
Thanks guys.
Lee.
When all TimeLine projects are triggered from Live->Buttons, there was no problem. But if you are in TimeLine tab and you manually press "play" to play a timeline, then it was not possible to trigger another TimeLine project from Live->Buttons.
It was not possible to put an event (scene or media) for instance a half second before the end of the timeline.
jaxx00974
Post by jaxx00974 »
OK thank you.
Regards,
Lee.
Return to “6.25 beta”
