Eurolite - LED KLS Laser bar
Re: Eurolite LED KLS Laser bar FX sæt
Done in 4 different fixtures (the only possibility to manage them correctly in the software).
So you have to declare 6 fixtures for each "KLS Laser bar", as following:
- derby at address x
- spot at address x+5
- spot at address x+10
- derby at address x+15
- laser at address x+20
- strobe at address x+23
Jump
Re: Eurolite - LED KLS Laser bar
Post by Jump »
Is it possible to make it for 27ch - like this:
http://www.haug-it.dk/Files/Filer/LED-K ... r-27ch.pdf
It is so, but you have to declare 6 different fixtures.
The reason is Generator is not able to manage multi-fixtures declared as one single fixture ; even Steps would not do that correctly.
Jump
Post by Jump »
But, just for my understanding... If I declare six different fixtures, they will get six different dmx adresses. And my physical unit only have one dmx address - so I cannot manage it?!
For instance, if the address of your fixture is 411, you have to declare:
- one derby at address 411
- one spot at address 416
- one spot at address 421
- one derby at address 426
- one laser at address 431
- one strobe at address 434
Jump
Post by Jump »
I got it - I just had'nt set the bar to 27 ch... It's working fine.
Michael
Jump
Post by Jump »
What if I want to use the bar in 3ch mode? Can you make a fixture file for that case?
Sorry, but we do not see how we could do this personality file, because depending of the value of channel #1, the functions and especially the key levels are different.
