Generate a scene crashes [fixed]
create lighting scenes
punkkipper
Post by punkkipper »
Everytime I try to make a scene using the scene generator it seems to be working okay until I go to export it back to the editor. It then crashes the program (and this happens whether I'm using it on PC or MAC).
ALSO,
when I put the scenes in the Live board and use buttons to cue them it adds an extra second on the end of each scene before going to the next scene.
can anyone help as this is extremely frustrating.
Re: Scene generator crashes...
Problem 1
We are not able to reproduce it.
Please send us your lightshow, with the Generator project which brings the crash.
Problem 2
This is a problem of an old software version.
Please install the current software version.
punkkipper
Thanks for the reply,
problem 1: where should I send the files?
problem 2: I downloaded the latest version off of the website---but just to confirm, what is the latest version? Could you direct me to a link so I acn redownload it? (I need it for MAC)
punkkipper
Sooo I downloaded the version you posted and now the generator doesn't crash when I export a generator scene back into the editor. HOWEVER...the generated scene just doesn't work now when played in the editor. There is no automation that takes place.
We are able to reproduce the problem.
We are working on it.
punkkipper wrote:Sooo I downloaded the version you posted and now the generator doesn't crash when I export a generator scene back into the editor. HOWEVER...the generated scene just doesn't work now when played in the editor. There is no automation that takes place.
The problem is due to the overlap of the point "1" and the point "2" in your Generator graph. Waiting we fix the problem, you can slightly shift the point "2" from the point "1" in your graph.
This is fixed in the fix files, in the beta folder.
http://download.thelightingcontroller.c ... ware/beta/
Caution: your existing Generator projects will keep not working. You must erase and redo them.
Return to “Editor”
