Which Drivers Should I See?
computer, driver, ...
5Starruk
Post by 5Starruk »
So basically my Xpress 512 isn't controlling my fixtures correctly at all, but the Obey 40 is doing a pretty well job with the faders.
I think it might be a software / driver problem, so my question is, which drivers should I see in my device manager? Is the BOX driver still in use or just D512 Interface 64bits (version 1.04)?
I really hope you can answer this quickly.. thanks.
ps. Using Windows 10.
Re: Which Drivers Should I See?
The driver for interface Box uses a too old system file for the more recent interface D512.
You have to update the driver with this one http://download.thelightingcontroller.c ... rivers.zip
And during the driver update process, you have to say "yes" to the message asking if you agree to replace the old files by new one.
5Starruk
Post by 5Starruk »
Okay, I already have the correct drivers installed correctly then...
The problem is, none of my fixtures are controllable by the software.
I have the fixtures dialed in correctly, the universe / interface is loaded correctly when opening the software, and I have the dmx option turned on but all that happens when adjusting the dials is completely eratic behavior from my fixtures.
Return to “General hardware”
