Control brightness using the Master Dimmer [fixed]
mondinga
Post by mondinga »
I have scenes in live that were created using pixels. I want to be able to control the brightness using the master dimmer. The master dimmer works on all lights, except for the ones being controlled by pixels.
Help please (=
Re: Master Dimmer with Pixels
Check the channel is disable in "Pixels > Fixture properties > "Shared channels".
mondinga
Post by mondinga »
They were set to 0. That's disabled, right?
If so, it was already enabled.
Please post (or email) your lightshow.
We will check that.
mondinga
Post by mondinga »
What is the e-mail address or can you PM to me?
In the window "Channels list" of the Master Fader, you have to check all channels (from "red" to "blue#18").
PS : when the fixture has a channel "dimmer" you can check only this channel.
Return to “Pixels”
