Gifs for pixels [fixed]
av-shack
Post by av-shack »
Hi, I've been trying to figure out how to get gif files into showxpress and have seen this reply from support:
If you put your new GIF files in the folder "../YourSoftware/TheLightingController/pixels_gif_files/", you should be able to use them in Pixels.
But for the life of me I can't find that folder. After "pixels" I only have a folder for projects. No "_gif_files" So please if anyone could shed some light on where I'm going wrong it would be very much appreciated.
Re: Gifs for pixels
The folder where is your software, and not the folder where is the lightshow.
av-shack
Re: Gifs for pixels
Post by av-shack »
Huh? I'm really sorry for being so dumb but I don't understand what that means?
av-shack
Re: Gifs for pixels
Post by av-shack »
ahhh got it now. Thanks :) Penny has dropped.
Thank you :)
rockinmo816
Re: Gifs for pixels [fixed]
Post by rockinmo816 »
I am not able to get the GIF to load in the software. I found the correct folder (under applications/software folder name/TheLightingController/etc....). I even tried to put 48x48_filename.gif format to see if that mattered. No matter what I do, I cannot get the custom GIF to show up in the software.
-josh
Please post your GIF file ; we will check it.
rockinmo816
.GIF file attached.
Josh
We made this new topic regarding this problem: viewtopic.php?f=71&t=4085
Please use the attached GIF file (transformed with "The Gimp").
rockinmo816
Just curious, what is the specific format(s) that are acceptable for the software?
josh
1-8 bits (animated) gif with standard encoding (ie. like does Gimp) will work.
Exotic gif encoded will not work.
Return to “Pixels”
