Welcome to version 6.00
please read this before posting
This version has been re-designed and re-developed from scratch.
The concept remains similar to previous version.
It is available for Windows and MacOS plateforms.
Presently, there is no available manual, and only English language is available for software text. So this version is suitable only for people who already have a good knowledge of the previous version, and who read English text.
The good points
In fact they are a lot of small things we changed, and the sum of all these small things make a more powerful and more friendly software. Here are some major changes:
- the software is multi plateforms
- the software works on 64bits platforms
- the software is compatible with multi OS users
- the software can manage up to 6 dmx universes (depending of processor speed)
- the software is multi projects (multi light shows)
- the applications Builder, Generator and 2DView have been merged into one single application called Editor
- the applications Backup, Restore and Stand-Alone has been included into application ControlBoard
- the applications use standard menus, popup menus and toolbar menus
- the applications use standard OS gadgets (standard buttons, scrollbar, menu, listbox, ... from Windows or MacOS)
- the software icons have been re-designed following a unique theme
- the software is very light (total size of all applications is 2,8Mb)
- the processor requirement has been optimized (no problem to use our software with a notebook computer, with some restrictions regarding 3D rendering)
- the software does not require the installation of any system file (inf, dll, ocx, ...) into the OS. This means you can simply move the software folder to another computer, and it will still work (the light show requires the use of Export/Import applications)
- refresh frequencies are much higher ; this means more smoothed fade transitions. This is important especially for led fixtures
Known issues
- Timeline and ScreenControl are not available yet.
- ControlBoard, Editor and Live must be re-started to see the changes made in Setup.
- Midi, dmx and audio inputs management is not available yet.
This new software is free for your usb interface (Cable, D512, Box, Remote and Ssa), whatever is the age of the interface (from 1999 until now).
This forum is new, so you have to register again to post in.
The software version 6 is available here: http://download.TheLightingController.com/software/V6/
The software updates details are here: viewtopic.php?f=9&t=8&sid=3f83e1ff12b40 ... 5881fc9129
Return to “Announcement”
