found by V5 and not found by V6, under same computer [fixed]
usb to dmx (2003 - 2010)
RoyalJenner
Post by RoyalJenner »
Hello
Is there a specific sequence of operations I am required to perform with the X-Factor & 6.x?
It appears to be hit or miss whether or not the box remains in stand alone or not. (note: I am activating the dmx output button in the software)
Re: X-Factor Box & 6.xx
If ControlBoard does not find the interface, you might have to upgrade its driver (current driver version is 1.04).
viewtopic.php?f=3&t=114
pogjack
Post by pogjack »
I am having the same issue with 6.25. The software will not send any signals to the DMX Chauvet Box. I have V 5 on the same system as V 6 and V 5 works except I think that having both versions on this computer freezes it up up and makes the lights go off.
I downloaded the driver 1.04 for the 32-bit box and attempted to install it, but it wants the disk for "The file 'EFKusb.sys' on (unknown) is needed. Am I doing something wrong or is there another file I need.
Thanks for your help.
During driver upgrade process, you can manually specify the path where to find this file.
It is located in same folder than the INF file (..\Drivers(Digitally Signed)\D512-BOX-REMOTE-SSA_for_32bits_OS\)
Return to “Box”
