Can't get Midi-Lighting on APC40
jcaniford
Post by jcaniford »
Im unable to get midi lighting working on my APC40, Ive got it enabled on live and midi out i have the APC40 selected but i can't get the lighting to work when i hit the button.
Re: Can't get Midi-Lighting on APC40
Did you follow this ? https://www.youtube.com/watch?v=SPQlxYXAz4Q
PS : we have an "APC Mini" and it works well with it.
To control the LED of the buttons, we have to:
- in window "Preferences", check "Midi out" and select the midi device in the combo box
- in window "Button trigger", check "Midi out", press the buttons "Clone midi in", and select "0" (instead of "auto") in the combo "Data2 Off"
Clgsound
Post by Clgsound »
The APC40 will light up and stay lit when selected from computer screen but not when selected from the pad itself. I believe this only happens with the APC40, i have the 20 and it works fine with that. the pads are velocity sensitive.
KarmaLighting
Post by KarmaLighting »
I am having the same issue. I even tried the Data2off 0-9 and got a lot of different colors which was cool but they would never stay lit when the button on the APC40 was pressed. Only stays lit when you mouse click the LIVE button.
djseismic
Post by djseismic »
Yes, I'm having the same issue. APC40 lights only stay lit when the scene is triggered with the mouse. Is there a way around this?
Thanks!
We suspect that, when the midi button is released, the midi device sends an extra midi message which switches off the LED.
Could you please use a midi sniffer software to report us all midi messages ?
After a quick Google research, we found this one for MacOS: http://www.snoize.com/MIDIMonitor/ (not tested)
And there is this one for Windows: http://www.midiox.com/
Earl Harvey
Post by Earl Harvey »
As stated previously... The APC 40 only transmits momentary triggers and not toggle...
Akai rectified the problem in their later products in the APC-40 Mk II, APC-20 and APC mini...
As a workaround, you can try to configure Live buttons as "Flash".
