Convert an external number pad to midi
Callum Allan
Post by Callum Allan »
Hi there, I've just come across an old external number pad keyboard i had lying around. I want to use this as triggers for showxpress and print the colors onto the keys but there are no numbers on the trigger selection in LIVE. Is there any way to program this or convert the pad to midi? Any help greatly appreciated.
Thanks,
Callum.
ShowXpress V8.2.28
DMX512 Interface
APC Midi Mini Controller
Re: Button Triggers Help
We think this is not possible.
lse
Re: Convert an external number pad to midi
Post by lse »
You can assign the numbers on keyboard trigger
pogjack
Post by pogjack »
Doesn't trigger only work on keyboard letters not numbers?
lse
Post by lse »
Do you own ableton?
Callum Allan
lse wrote:You can assign the numbers on keyboard trigger
This isn't possible. Only ABC can be assigned. I have ableton but not on the lighting PC.
ShowXpress V8.2.28
DMX512 Interface
lse
Post by lse »
Use a internal midi device to convert key triggers to midi
lse
Post by lse »
I use ableton to merge 4 midi devices and send to Sx
zkflow
Post by zkflow »
Callum Allan wrote:Hi there, I've just come across an old external number pad keyboard i had lying around. I want to use this as triggers for showxpress and print the colors onto the keys but there are no numbers on the trigger selection in LIVE. Is there any way to program this or convert the pad to midi? Any help greatly appreciated.
Thanks,
Callum.
actually you can't convert numbers to midi notes... but what you can to its convert numers to specific keys in the keyboard... in other words, the keys that you can actually map to the software... the software is called MacroWorks 3.1... and there are many tutorials about how to... i used in a project similar to yours... with only a numeric pad i mapped for example:
number "3" -> letter "a" and with a little num. pad we controlled the lights from a restaurant-bar... it was nice...
