Light not showing in 3d view
bones2020
Post by bones2020 »
Hi
I made my own fixture file for my ADJ VBar Pak and also for ADJ Mega QA Par38.
When I open the 3d viewer to start and program my lights and to see what they are doing in the 3d viewer it doesn't show me my fixtures in the 3d viewer.
There is no fixtures there in the 3d viewer.
How do I get the 3d viewer to show me my fixtures that I have made and what they are doing
Many thanks in advance
bones2020
Re: Light not showing in 3d view
Post by bones2020 »
Ok i worked out what i did wrong. This was me being a nooby lol
I didnt set the lighting fixture 3d settings when i was making the fixture file for the lights. Once i went back and see it i set the setting and it all worked out fine.
Im a work in progress :-)
We suggest you to use our library: viewtopic.php?f=25&t=3839
bones2020
Post by bones2020 »
Hi thank you.
Is there any advantage using the file you have made over using my own made one.
Like is there any pros or cons using own made fixture file vs your made file
We just supply the library as support.
You can either use it, or use yours.
