Intensity of "colored object"
DeeStage
Post by DeeStage »
Hello ;)
Im trying to visualize my 8 Seg. RGB LED Bars in 3DView...
Because there is no option to show Multiple beams for one fixture, I devided each LED Bar in 8 single Fixtures with just the RGB channels... so I was able to show every single segment in 3DView as an little Object ...
This worked very fine for pre-programming but i had a big Problem at the gig...
My Fixtures were much too bright so i had to dim them down to 10%
---> Now i couldnt see any response of the Segments in 3DView because they were just too dark now...
Request ---> I think it qould be a great idea to:
1.) Make an option that allows to exclude 3D View form the Submasters... so the Submasters will only work for DMX Mode if you want this (by ticking a box)
2.) Adjustable Intensity for 3D Objects (as you could to it for Par Cans or MHs)
DeeStage
Re: Intensity of Objects
It looks like, in the window "Edit Fixture" section "3DView", you set the "segments" to "colored object" (?)
If yes, we note that we should add the possibility to adjust the parameter "power".
DeeStage
Post by DeeStage »
Yes you're right...
Thank You ;)
