Swarm 5 3D View Error
djsounds
Post by djsounds »
Hello
The 3D view of the swarm 5 is not accurate.
When you add the light fixture to the 3D view a light turns on by default.
Can you please fix this issue.
John
Re: Swarm 5 3D View Error
Please post (or email) the personality file ; we will check it.
djsounds
Post by djsounds »
I am using the profile that is built into the program version 7.1.54
See attachment
John
swarm 5x.txt
(2.57 KiB) Downloaded 907 times
Sorry but 3DView is not able to show such "complex" fixture (viewtopic.php?f=13&t=668).
Here is the fixed personality file with setting "not visible in 3DView".
djsounds
Post by djsounds »
I understand that i can't see high end effects but a white light is turned on in 3D view as soon as you run the program.
See picture.
Please fix it.
djsounds
Post by djsounds »
Nerver mind I used your new profile and the white light turned off.
AHB
Post by AHB »
A simple work around is to open the fixtures properties and rename selection 4 (Shutter) to "dimmer effect" then this gets rid of the open at all times issue in 3D not affect selections etc and allow some strobing if wanted on 3D. If you import the suggested profile it will just sit there and do nothing. Works for me.
