fader "red" does not respond [fixed]
create scenes with steps
PEDCLIGHT
Post by PEDCLIGHT »
The delay I was talking about is the channel 1 fader of my Lustr+ fixtures while in the steps screen. I am just working with the laptop and the software...not connecting to controller or any actual fixtures. When trying to push the fader on channel 1(red) on universe 2 the fader does not respond right away. It will eventually move after a couple of seconds. I believe their is a conflict between the red and cyan colors. I changed the cyan color on channel 5 of the fixture to ucyan and this enables the channel 1fader(red) to move freely. I did notice that when moving the channel 1 fader that the ucyan fader also turns green? If I change the ucyan color to yellow this does not happen. I have also opened my light show in version 6.333 and the faders work normally. There seems to be a conflict between red and cyan/ucyan on the new version of the software. Let me know if you are able to duplicate this. Thanks
Re: 3DView Crashes
We are able to reproduce the problem.
We will check that and come back to you, as soon as possible.
Re: 3DView Crashes
Fixed for next release.
PEDCLIGHT
Re: 3DView Crashes
Post by PEDCLIGHT »
Perfect. Thank you for your help.
Re: fader "red" does not respond [fixed]
The fix is avaliable here: viewtopic.php?f=2&t=3677
Return to “Editor - Steps”
