[6.00] refresh problem after changing the light show [fixed]
marco
Post by marco »
hi
first the new version looks great
but now my problem. i use different shows with different fixtures.
when i switch the show in the settings menu it changes in fixtures and editor, but it doesnt change the 3d view.
also in my different shows it saves the same 3d view files. have u seen this problem your self 2?
Re: 3dview problem
There is effectively a problem ; we are working on it.
In the meantime, there is a workaround: each time you change the light show, you must close ControlBoard and restart it. Then 3DView should display the correct light show.
Re: [6.00] refresh problem after changing the light show
Because changing light show is not done very oftenly, we chosed for now an easy solution:
We added a message which ask you to re-start all applications (including ControlBoard).
This is available in the fix files.
gilsontech
Re: [6.00] refresh problem after changing the light show [fixed]
Post by gilsontech »
support, is this going to pop-up everytime now? How often? I ask becuase I have the software in several applications that run 24/7/365. Thanks.
Working on the next BIG thing
When the user will create a new light show or when he will select another lightshow in ControlBoard->Settings, he will have to close the applications (ControlBoard, Setup, Editor, Live, ...) and re-start them (no need to re-start the computer).
