external monitor makes lights crazy [fixed]
usb to dmx (2003 - 2010)
yogaf
Post by yogaf »
Hi All,
I need help. I am using a new laptop (Core 2 Duo w/ 512MB Ram and WINXP pro) replacing my old desktop. I got problems that maybe anyone also encounter this. Here is it
1. My first problem is when I connect an external monitor to my laptop and the X-Factor then light going crazy (DMX signal is gone) and light blink by itself uncontrolable. Right after I unplug the external monitor everything just work find.
2. This also happen when I plug an audio cable to my laptop headphone jack to audio mixer to play my timeline, is also going crazy (with same symptoms). First I though is my phone jack so I unplug my the audio cable and use an earphone - and it works just fine. So I though is my mixer so I use the audio cable directly to a speaker (powered) is also GOING CRAZY.
Please let me know, if you know any fix or any input.
jaxx00974
Re: HELP - X-FACTOR
Post by jaxx00974 »
Had something similar,
3 things you can try:
If you have a terminator, then remove it
If you dont have a trerminator, then try one in
lastly, run a dmx cable into the showxpress unit from your last fixture.
Onoe of them should settle your problem hopefully, It did for me.
Lee.
tomrbland
Re: HELP - X-FACTOR
Post by tomrbland »
Also try taking the power lead out of your laptop, and run on battery. I have had problems with my audio before that has been related to the laptop power supply.
yogaf
Re: HELP - X-FACTOR
Post by yogaf »
Thanks for all the response
@tomrbland
I tried run the laptop on both with power adapter and battery, both doesn't help
@jaxx00974
can you explain what do you mean by "lastly, run a dmx cable into the showxpress unit from your last fixture." Do you mean run cable from the last fixtures to DMX in?
jaxx00974
Re: HELP - X-FACTOR
Post by jaxx00974 »
Correct, this closes the loop and sometimes does help.
Good luck,
And mind check for a faulty cable.
yogaf
Re: external monitor makes lights crazy [moved]
Post by yogaf »
I tried the loop (from the last fixtures to DMX in on x-Factor) - It doesn't fix my problem... I will try the terminator in the next view days (wait till it arrive). I just rewire all my cable - but I will recheck when the terminator doesn't give any result.
Will keep updating... Thanks
May be this problem (?)
viewtopic.php?f=15&t=374
yogaf
Post by yogaf »
dear all, Thanks for all the input and answer...
I tried all... use terminator and not... loop the cable... NOTHING works... But I figure that the problem is coming out from 1 of my light (1 of my Yokes - CHAUVET MIN Spot LED - I got 2 of them). If I don;t use external monitor is all find.. but when I plug external monitor (laptop) OR plug my audio to audio mixer the ALL the light (PAR included) is going crazy. But when I unplug this MIN SPOT - everything just fine... I don't know what happen? I think I need to call CHAUVET for that.
Again thanks all for the help
Yes, please call them directly for this problem.
Return to “Box”
