[Fixed] My 3D Imager has gone wonky for 2 of my Fixtures
Post by Pink LD »
My Chauvet 150 spots I use as performer halos are generating their beams on 3D via LED pars in the rig?!? I can't get the beams to image out of the the correct fixtures.
Earl Harvey
Re: My 3D Imager has gone wonky for 2 of my Fixtures
Post by Earl Harvey »
This has also become a source of aggravation for me as well...
I'm curious what is the maximum amount of fixtures per universe ? in 2-d as well as the fixtures page?
im using over 50 in a single universe...
Are you able to post an easy lightshow showing this problem ?
Post by Pink LD »
I would like to think you could control up to 512 single channel fixtures per universe.
Post by Pink LD »
Turns out something was patched in the same channels, I finally found it and removed it. Problem solved. I did not know that in some circumstances you can patch separate fixtures over each other, and I don't mean clone, I understand that.
