fixture with "red, red, red, green, green, blue" [fixed]
create lighting scenes
directsound
Post by directsound »
I have a Eliminator Lighting Model Electro 196 par can it has several rgb chanals on the same fixture but when i use the color whele it just grabs the first r or g or b chanel and not all of the reds or so on here is the profile I made and the link to the manaule it see if we can fix this as the light is at about 50% WITHOUT groubing the rgb chanels
http://www.eliminatorlighting.com/pdffi ... tro_196_ii dot pdf
thanks for your time
dj mikey mike
I cant ad the fixture file for some reason so I will copy the text from it and past it to the botom of the page
ViewType = VIEW_TYPE_PAR_CAN
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 20
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = TRUE
ViewReverseIris = FALSE
ViewColor = 16777215
Channel = dimmer
open,0,0 strobe,3,3 strobe,25,25 strobe,50,50 strobe,75,75 strobe,98,98 closed,115,115 auto,130,130 auto1,150,150 auto2,189,189 audio,195,195 audio1,225,225 audio2,255,255
Channel = red
dimmer,0,255
Channel = red
dimmer,0,255
Channel = red
dimmer,0,255
Channel = green
dimmer,0,255
Channel = green
dimmer,0,255
Channel = blue
dimmer,0,255
Channel = blue
dimmer,0,255
Thanks,
From DJ Mikey Mike
http://www.directsound.com
Re: Group rgb Eliminator Lighting Model Electro 196
We made the attached profile.
Effectively, the RGB color wheel is lost with a fixture having following channels "red, red, red, green, green, blue, blue".
The lonely solution is to use the sliders.
[deleted]
directsound
Re: fixture with "red, red, red, green, green, blue, blue"
As you can see I made a profile ...did I do it wrong or did you change something?
I just want you to be able to group multi colors to work with the color whele..if it cant be done I understand but it seemed like and option.
thanks
Mike
Thanks,
From DJ Mikey Mike
Your file is ok ; we changed nothing.
Our problem is the manufacturers create new fixtures with channels, not in order, or like this fixture: 3 red + 2 green + 2 blue. We do not understand why different quantity for each color ! And think about us of how to manage that ! May be next fixture will have have 10 red + 5 green + 1 blue !
You are right ; we will do like this: the RGB wheel will drive all RGB channels from the fixture, whatever is the quantity of each color (added in TODO list).
kahilzinger
Post by kahilzinger »
I heard that Yellow may be added to RGB down the road in some fixtures as a fourth color. You might want to start thinking about that.
tomrbland
Post by tomrbland »
kahilzinger wrote:I heard that Yellow may be added to RGB down the road in some fixtures as a fourth color. You might want to start thinking about that.
I have used fixtures with RGBYW - they are all ready out there...
In current software, the RGB wheel drives all RGB channels from the fixture, whatever is the quantity of each color.
Return to “Editor”
