Midi input in HTP mode does not work in 3DView [fixed]
MTF Showtechnic
Post by MTF Showtechnic »
I've assigned a red channel of a PARCAN to Midi by a rotary knob like the following:
CH2 - CC8, Priority ->HTP, DMX Channel 25
Made a scene for the PARCAN Channel 25(Red) Value 127, Channel 32(Dimmer) Value 255.
Assigned that scene to a button of Live Page and started it (Editor DMX & 3D View off)
Now I turned the rotary knob expecting that all Values greater than DMX Value 127 (this should be 64-127 of Midi)will increase the brightness of that red channel.
But HTP want work!
If I use Midi or Software as Priority everything is as desired.
Only checked that in 3D View - not live with DMX Equipment.
Is it a bug or am I doing wrong?
greetings from germany
Re: Bug in Midi at HTP ??
We just re-did a similar settings than yours (with V7.1.46), and it works with us.
Can you please double check with the "DMX channels" window (not the 3DView window) ?
MTF Showtechnic
Checked - and alright. In the DMX Channels window I can see the expected behaviour.
Bug's in 3D View.
Gonna check it with DMX Equipment on saturday. Then you'll get another feedback.
greetings and thanks again for your excellent support.
After a quick look in the source code, it might be possible that dmx output is ok, while 3D is not.
So you might be right.
We will come back to you asap regarding this matter.
MTF Showtechnic
Sorry for the late answer: Priority HTP, Software, Midi with real Equipment works without faults.
Bug is in 3DView.
And a little blemish - see the attached picture.
German Text is in the file but this is the result.
It's in Preferences -> DMX & Midi Patch -> DMX Output.
greetings
Wrong German text and 3DView bug are fixed for next version.
MTF Showtechnic
Re: Midi input in HTP mode does not work in 3DView [fixed]
Hey,
I just downloaded the next fixed .exe File 7.1.50 and the .ini
But it looks like that you've forgotten the wrong german text!?
It's still wrong :(
3DView Bug checked and fixed.
You have also to copy/paste the ".ini" language files from the zip, in their correct location.
MTF Showtechnic
Yes I've done this.
Checked on 3 Pc's. Doesn't work.
Location on my PC's : Sweetlight - TheLightingController - Language.
We just double checked ; you are right.
It is a small mistake with a non expected capital letter ("Txt_DO_Universe" instead of "Txt_DO_universe").
Fixed in the attached file.
