MIDI controller for editor
rockinmo816
Post by rockinmo816 »
Can you assign MIDI faders to channels in editor? This could help speed up the process of programming shows. I don't see an option to assign MIDI anywhere in editor so I am assuming not.
Josh
Re: MIDI controller for editor
Sorry but we use midi exclusively for live playing, and not for programming.
mondinga
Post by mondinga »
Is there a place for feature requests in this forum? I agree that this would be highly beneficial in programming mode as well as in live mode.
I would also like to be able to control a channel assigned to a dimmer pack using a fader. That seems like a very basic feature that should be available. :roll:
rockinmo816
You should be able to do that. Create a scene with one step of the dimmer channel to 0 and the second step to 255. Then save the scene and add it to a button in live. There is an option on the right click menu called fader button. Then link that button on the midi controller. We do this for strobe rate.
-Josh
You also can use "Midi Patch" in Preferences for that
mondinga
Post by mondinga »
Josh - That worked like a charm.
Niffo - I was able to use midi in preferences, which does work, but its global and could cause some issues when you are running your show. If someone forgets that a channel has been assigned in preferences, they might not realize why their lights aren't coming on. But, thank you for sharing that as well. Its good to know different ways of doing things, as they may each have their own application.
THANKS GUYS!
