Renaming LightShows [fixed]
djsounds
Post by djsounds »
Hello
I am running version 7.1.12
Is there a way to rename a current light show using save as command.
I see the save as command for scenes but not for Projects.
This is what I see in the Files Menu
New lightshow
Open lightshow
Import lightshow
Export lightshow
Open lightshow Folder
My goal is to keep the LED layout of my light show but add some new LED uplights layouts.
!2 LED uprights
18 LED uplights
24 LED uplights
Thanks for your help.
John
Re: Renaming Projects
"Rename lightshow" does not exist in the software, but it is quite easy to do:
- select "Open lightshow Folder" to open a window showing the contents of the folder "LightShows"
- you will see one folder per lightshow ; in fact, each folder is a lightshow
- you can copy/paste, delete, or rename a folder
- afterwards, when you select "Open lightshow", you will see the change
