[MacOS] Screencontrol doesn´t appear
sportkeps
Post by sportkeps »
I just upgraded to V.7 and have two problems:
- Screencontrol doesn´t appear, no movie is possible to show.
- Waveform only works in some of my saved timelines.
Use Macbook Pro with Mavericks OS X 10.9.5
Thanks!/Gustaf
Lighter007
Re: Problems with V7.1.23
Post by Lighter007 »
Try using uncompressed formats like .wav for Windows. -> Waveform only works with that.
Might be the same, try using uncompressed formats.
Greetings from Germany! :)
sportkeps
Post by sportkeps »
Thanks for your reply, the weird thing is that i only use .wav and .mov, and it works fine in V6.? I can´t find anything different with the .wav-files. About the screencontrol, It feels like something is missing. When i press the button "screencontrol" under the meny, nothing happens. I don´t find any file called screencontrol in the sweetlight folder like in V6, i´m i supposed to do that?
Best Regards, Gustaf
Lighter007
Hmm, yes, Screencontrol seems to be missing.
Did you tried re-installing the hole software?
We just checked with our Mavericks and software version 7.1.29, and we are able to open and see the ScreenControl window.
Re: [MacOS] Screencontrol doesn´t appear
Waveforms are only displaying with Wave PCM file format (for example the default save file format of the free software "Audacity")
sportkeps
Post by sportkeps »
Thanks Niffo! That helped me with the waveforms! Any clue on the screencontrol problem..? this is what my folder looks like, anything missing? i don´t se anything about screencontrol, am i soposed to do that..?
/Gustaf
In V7, ScreenControl is integrated in the main software, so it is normal not to find a "ScreenControl" file.
The ScreenControl window is supposed to open when you call it from the "Windows" menu of the software. May be the window opens behind the main window ?
Regards.
Maybe the ScreenControl is opening outside your screen. Try to delete the file "TheLightingController/{yourlightshow}/ScreenControl/screencontrol.ini"
Return to “Live - TimeLine”
